Welcome Guest - Sign Up today
No announcement yet.
2001 johnson 50 hp runaway idle
  • 2001 johnson 50 hp runaway idle
    When raising fast idle lever engine starts but idles at high rpm after lever is pushed down to seated position. Any ideas? Thanks
    Is this something that developed suddenly ?
    • #3
      what happens engine side when you move the fast idle lever do all linkages move accordingly ?
      • #4
        You may need to adjust the throttle cable at the engine.
        • #5
          Fwiw, mine (J50PLSSM) would do the same thing, got a bit worse over time. Also my timing was off 5+ degrees during my last monthly check-up, I noticed that the roller on my linkage was REALLY worn out.....was not pushing the linkage back when I throttled down, or for that matter never got WOT.
          • #6
            What’s the best way to adjust the throttle cable? I have a 1989 Baja islander 190 mercruiser 3.0. I noticed while I was doing some things under the hood I would put it in throttle only and rev it up. Put it back in neautral but would still rev at a higher rpm. Not to bad but higher. I would have to manually go to the carb and push on the cable and push it back down. I don’t know if the carb is sticking or If the cable is sticking and not wanting to go all the way back to where it should be. Thank you
