Timing vs. Carb issues on OMC engines
thatone123
Banned
What do you consider the most obvious signs of timing issue problems. vs. Most obvious signs of carb issues?
Timing generally does not go out of adjustment on your modern motors !
F_R
Probably more common are the synchronization or links between the two.
