thatone123
Banned
- Mar 7, 2009
- 707
Attached Photo. This engine has about 95 psi compression and seems to run with authority except it tens to cough a little than idle down and stop unless I keep it revved up manually. Put some Evinrude tuner through the carbs and they run a little better but still same problem. Hoping I would not have to clean carbs but doable. Does that sound like a carb cleaning issue ? AS to the control cables are these vintage cables the same as to pushing and pulling the same distance? You don't need a shifter cable for a jet so it just has one cable hooked up. I noticed that when I put the throttle forward, the choke solenoid would push out and then go back in and this did not seem right of course. IT will start when I manually choke it, but that solenoid does not seem to work or might the other cable be the better one??? I bet it is hard to find a new solenoid as I have not even found a schematic that shows one.
