hello , i see thread about test bench cdi without motor, but i dont find any results there. its look simple. for the max simplicity of ignition lets think engine have 2 coil, one charge coil that charge capacitor inside of cdi, this charge coil provide about 300-500v ac depends on motor. second coil is trigger coil that produce small voltage about 5-10vac , so when trigger coil produce 5vac this voltage go to cdi and trigger scr that release voltage (300-500v) stored in capacitor to wire that go to hv coil that is connected to sparkplug. so i think that, if i have cdi, and dont have engine, to test cdi, i should apply voltage lets say even 50v to 2 wire going to cdi, one ground wire , and second wire that is normally conected to charge coil, this should charge capacitor to about 50v right? then next i provide small voltage to two wire simulating trigger coil, so one wire is ground, and one wire its that wire what go to trigger coil , and then send 5v so that cdi think that its time to give spark. before i apply 5v on trigger wire, i connect dmm one lead to ground, second lead to wire thats going from cdi to iginition coil , and in the moment that i send 5v to trigger wire, i should see on dmm aobut 50v on wire that going to ignition coil right?
