1966 as was said, the drive pin was relocated. The bigger picture is that they switched from a shock absorber in the lower unit to a splined prop shaft. Just so you couldn't run an early non-spline prop on a later non shock absorber lower unit (or vise-versa) they purposely made it so props between the 1954-64 5½ & 1965 6-horse are not interchangeable with the 1966 through 1979 6-horse.
For 1977 they switched to CDI ignition. Supposedly better, but if the CDI box fails it is expensive to replace.
I think any 1966-76 6-horse is your best bet.
A little history as far as the lower units are concerned, the 1954-55 Johnson 5½ & Evinrude 7½ shared a 1st generation "Aquasonic" or "Suspension-Drive" lower unit with a detachable exhaust bypass cover. Gale also used them 1956-59 on their 5-horse.
They redid them for 1956 into a sleeker style with lower swivel bracket rubber mounts under "muffs" and were used on both the Johnson & Evinrude 5½ & 7½ (Gale used this as well on their 5 from 1960-63). This midsection & lower unit shared the guts & foot with the earlier style. The later style looked the same from 1956 through 1979 except the bump or "hook" that ran in line with the prop shaft forward was eliminated for 1968. (compare the 1967 "bump" to the 1975 "no bump" Evinrude pictures attached)
