Rrosenbloom
- Feb 10, 2019
- 11
As I continue to explore the "new" old motor I bought, I was checking the impellar and wasn't able to slip it off the driveshaft over the top, so I just pulled the drive shaft out and removed it from the bottom. I put everything back together and didn't notice anything wrong, but when researching replacing seals and whatnot I came across an instruction that says if you pull the driveshaft out, you have to disassemble the gear box and align the pinion with the shaft..etc. That true? I can turn the driveshaft with my hand and it grabs gears and spins the prop forward and reverse.
