Omega Whaler
- Mar 10, 2019
- 5
In the process of restoring my 76’ Evinrude 50 HP that I recently purchased with my Whaler then bad luck hit. When I was working on removing the lower unit the four bolts that are on the sides of the lower unit, snapped. Yes, all four heads snapped right off and left a white powered. The bolt by trim tab did not give me any issues. So, now I can’t get the lower unit to drop down. I did remove the shift linkage. I’m thinking that just a little bit of thread is left holding the two together. Because of the fins, I don’t believe that I can get a drill to remove the old bolt.
Any ideas would be greatly appreciated.
Thanks
Thanks
