Michaelbroussard
- Mar 7, 2019
- 4
2001 225 Evinrude 225FHSIF. I am having multiple issues that have had me all over the place. All but one is now solved. Here is what I am dealing with. I can plane out and run 3500 rpm fine. Once I trim up a little and get up around 4000-4500 the motor kind of levels off at 4500 and about 5 seconds later my check engine light comes on and puts me into limp mode. I turn it off and it will fire right back up. I can do this over and over. It started a few years ago and would do it in rough water only. Then it got to happening when I made a turn last year. Off and on very sporadic. Now it doesn't matter. I have checked stator per the manual testing the ohms. It's good. Battery load test is good and it is a 1000 cca battery. I have looked over all ground wires, taken them off, cleaned, and reinstalled them. Battery cables are good. I have wiggled and shook wiring harness over the boat. I can't make it happen until it is under a load in the water. I have brought it by the dealer several times. The only code that will show is 26. Low voltage detected check stator wiring etc. What I have been told is that the code 26 is not supposed to put me in slow or limp mode. Possibility in my mind is the emm. I have spoken to a few of the folks that rebuild them asking if the reg/rect may be the issue. He said it normally is either working or not. Shouldn't go in or out like I described it doing. It would also be throwing the 40v code at the same time if that was the issue. He said he's never seen it before but the soldered connection may have came loose allowing contact all the time. With the little vibration it may be possible it vibrates away from the connection just long enough to throw the code. Last Saturday it happened 27 times according to the dealer. I have had EMM issues 3 times now that made sense to everyone. This one makes sense to no one I have spoken with. Not a common issue. Running at the dealer on muffs and running at the house on muffs I have no issues. Regardless to the steering position, trim angle, or RPM. I am going to bring a lap top with me to the lake this weekend. I am going to have it monitored so we can see everything happening play by play so we can tell if the voltage drop is steady and makes sense or if it just throws the code instant. Am I missing anything or is the EMM once again making this thing go crazy?
