osuchica1284
- Aug 21, 2017
- 26
I have 2 lower units - one is seized and was off the boat when I bought it, the other is on the boat. I THINK the one on the boat is the original to that motor but I want to be sure - both lower units are about the same dimensions and near as I can tell (based on sterndrive.info) both are large v6 gearcases compatible with my 1989 200hp vro, 25" but I want to be sure. The main differences are a broad cavitation plate vs thin and 2 slots above the cavitation plate vs 6 holes. It also looks like the thin cavitation plate has holes for zincs whereas the broad cav plate does not.
shop2.evinrude.com parts breakdown shows my model motor having a lower unit with 2 slots above the cav plate
Is there any way I can tell what they are without tearing them apart and cross checking the part numbers of the internals? Thanks!
