havoc_squad
- Mar 5, 2011
- 702
Would a 1988 110 HP engine block be an exact replacement for 1990 V4 crossflow block? Someone very recently is selling a machined block (3 holes 0.02, 1 hole required 0.04 oversize) for $150 within reasonable driving distance. I would be more inclined to buy it except the 0.04 hole. Would it be best to just use what I already have if the worst it needs is 0.02 or buy the already machined one and replace the essentials? I am planning an engine disassembly in about a month or so to free up stuck rings on starboard cylinders and have very light piston ring scoring I'm top starboard cylinder at 12:00 position. If I have to spend around 400 dollars in machine work and shipping to remove typical wear of a motor never oversized, is that better than having one ready to go for 150 but has to have the 0.04 hole resleeved if out of spec?
