San Diego101
- Feb 26, 2019
- 3
Recently picked up a small aluminum skiff with a (mid - 80's?) 15 HP 2 stroke evinrude after my boy showed an interest in fishing. We mostly chase yellowtail off La Jolla (& mostly catch bonito, but that's ok - still heaps of fun!). After a dozen trips last fall, the engine cuts out at higher RPMs. It runs at low RPM's fine. I've changed the fuel filter and spark plugs and nothing obvious with the fuel line, bulb. If I pull off the fuel hose to the engine and run it does same. So, I'm thinking the problem is inside the motor, somewhere (clogged carb, some internal filter?) Any suggestions on how to troubleshoot, would be greatly appreciated! Also, before purchasing, I had the engine inspected by an evinrude approved boatshop mechanic, who said it was fine (for it's age), apart from motor mount wear. For my purposes, he suggested just running it until it needs repairs and then look at replacing (which was ok by me - the boat is a little newer and was worth the cost. But I'd sure like to get some more seasons out of the engine.) I'm completely new to boating & outboards. Altho somewhat familiar with small engine from tinkering on 2 & 4-stroke engines as a kid. I'd sure appreciate any advice or thoughts on the above, as well as what I should be doing for normal maintenance on a regular basis.
