Mthirsch14
- Jan 26, 2019
- 46
Finally got all the kinks worked out after having electrical issues and took her out on the lake. Everything seemed good got up to plane and was cruising for maybe 2minutes then when I decided to pull back and slow down I was at maybe 1/4 throttle and the engine started violently shaking side to side. I ended up turning the key off to prevent damage so I’m unsure if it would have died on its own or stopped shaking once I slowed down more. I check both plugs and there was a good spark. Even tried starter fluid but nothing I did got any combustion. Any ideas on what would cause it to shake very hard side to side? And why it won’t fire when i have spark and fuel?
