GaJeff
- Jul 9, 2012
- 149
1975 Johnson 50hp 50ESL73R
Finished a power head gasket set and there was a rubber vacuum boot shoved in this hole... I removed it knowing something like this would probably happen... Here I am.
What is this hole for and why did the gasket not cover it? The gasket set is correct for the serial number. It only covered a small strip down the center of the hole.
Should I put a rubber cork in it or is there something supposed to go there? I searched the parts diagrams but it shows nothing for this spot.
