I recently purchased a 78 Johnson 115 v4 model 115ETL78C. Boat ran great for approximately 2 months. Idleing back to the dock and it started missing. I have good spark, clean fuel, but low compression on one cylinder and that cylinder is not firing. Good spark from all coils, will all jump a 7/16 gap. Compression numbers are as follows: 122, 120, 117, and 103. Cylinder at 103 will not fire. This boat has never been in saltwater previous owner states motor always ran strong. First question is..I know that’s around 20% lower than the other 3 cylinders, but should it be firing? Question 2..with it being a 78 is it worth the money to have new sleeve, rings and piston on that lower compression cylinder replaced? Thanks in advance for any help/info!!
