I have a 1999 Fast Strike J150PLEES. When it gets to the end of the tilt, and gets into trim mode, It acts like the battery is dead and will barely move and even stops. When it gets back high enough to be in tilt mode it takes off again. When it is low enough to engage the trim cylinders the motor has trouble if you are going up or down. Any thoughts?
