Is the motor overheating? Too hot to touch under the head? It may be that the water tube is blocked by a damaged grommet, or not in the grommet. Could be the water passage around the cylinders is blocked somewhere.
Motor may be seizing up when overheated.
[If running in a test barrel, the water must be well above the impeller.]
