I tore this motor apart about 6 weeks ago (my first go) and after much research and getting parts, I got it back together fine and had the whole thing mostly ready to test. While waiting for my last couple of parts, I stumbled across some writings by a guy named LeeRoy Wisner, who seems like he knows a lot about these motors. A point of great importance was something he called "internal concentricity" as it pertains to the alignment of the con rods and caps. I had checked the alignment on the outside of the castings, but not the inside surfaces that house the bearings.
Since I had the time, and didn't want to chance it, I pulled the power head again and decided to check it right. Everything was OK there, but my concern is that the sealant I used on the crankcase halves (Permatex 51817 anaerobic gasket maker gel) had not set up at all after a week. I've since read of other options, but I'm wondering if anyone else here has ever used that stuff? The mating surfaces were absolutely flat, smooth, and burr free, so I know it wasn't that. What sealant should I be using for this motor?
