TN 28 water pump impeller replacement
3DHUSKER
Do i need to drain lower unit oil or can i just unbolt and drop it? Is there a thread on this? Sorry I am a nube on this TN 28 as I acquired it from my father that passed a year ago and I am trying to get it running.
3DHUSKER
There is a cable that puts it in neutral. Do you have to disconnect inside where you unbolt it to get to the WP? I currently have the cable disconnected at the top end as I have the flywheel off and replacing coils,points and capacitors. Just trying to get a plan together before i dive into the bottom end. This place has given me the confidence to do the top end. I have to research the carb also as I am sure it is a mess as this has not run in 18 years. Yikes i know could be a mess.
Crosbyman
you will find all the info in the LU section of the johnson red book pages 374and up on the boat info site … just print off what you need and yes you must disconnect the neutral cable and… reinstall it properly
http://www.boatinfo.no/lib/johnson/m...nson.html#/388
btw I have one restored … waiting in the shed…. magneto is the standard magneto your coils are likely shot and the whole
mag plate needs to be service … easy as pie…. get some solid core plug wire and replace while you are it
http://www.leeroysramblings.com/johnson_magneto.htm
you may need leather seals in the primer pump and you must clean out the bottom filter screen the float may be crumbled so you need a new one
visit the POCHE family site carb and LU jobs listed
http://www.pochefamily.org/outboard/CarbService.html
http://pochefamily.org/outboard/
3DHUSKER
Sweet, Where do i get the solid plug wire? I am sure the coils are junk by the looks. I can get coils at local parts store along with tune up kit.
Crosbyman
Crosbyman
you can buy solid core plug wire on amazon but your local motorbike shop probably has some nd will sell you 4 feet
DO NOT BUY CARBON HIGH RESISTANCE WIRE FOR CARS
F_R
I see lots of guys referring to "solid core plug wire". I'm sure they know what they are talking about, but it may be misleading to others. It isn't actually solid core, but is stranded metallic "wire" core. What everybody is trying to convey is that cars built in the last 60 or 70 years or so use a carbon-filled string as a core. That stuff is no good for outboards. Look for "wire" wire at lawn mower shops, tractor shops, motorcycle shops, and yes even outboard shops. Some auto parts stores stock it too, but others will give you that blank stare.
Crosbyman
true… the wording is important … 7 mm wire core…. strand core… solid core all good but not CARBON wire core
3DHUSKER
Thank you for the information. I have a lot of work to get done in a short time as it will be time to get on the water real soon.
3DHUSKER
I now have spark and will pull the carb off tonight. Making headway little by little.
Crosbyman
I resealed my cork float with crazy glue ( careful with fumes with eyes and lungs)
sand the cork a bit and apply 2-3 layers of liquid crazy glue or 2 layers of airplane DOPE sealer (aerogloss) or.. get a mercury float
clean the bottom plug wire mesh etc according the Poche family article
2 leather seals will be needed on the priming plunger ! mare sure you install them oriented the correct way
there is a filter on top of the fuel valve ….. you should unscrew the valve and back flush the filter
but how is compression on this oldy
3DHUSKER
Ok... I finished the carb and decided i wanted to see if it runs. This thing purred like a kitten for a while then just went sour.
Had no power and sounded like it was running on 1 cylinder. Pulled # 1 wire off and no difference. pulled #2 and it died. Put wires back on and ran it again it all of a sudden had power so I pulled #1 wire and it sounded like it did before. plugged it back in and it ran good for a bit then went to missing again. I think I have a coil that drops out and then back in. It is the only part that has not been replaced. I pulled it apart and everything else looks good. Think I may just replace both coils while i am in there again. They both tested good and look new but now I think one is suspect. What do you think?
3DHUSKER
I ordered a pair... It sure sounded good when running on both cylinders.
Crosbyman
i have a nice tn27 ready to go…. in the shed all reworked with pump leather seals and all but…. water conditions presently not compatible with boating :smow:
green wire has been rerouted
Nice simple motor .-----Not even any reed valves to make noise or fail.
3DHUSKER
Used 3/8, 5/16, #10 Nylon washers from lowes for the screws on the carburetor for future reference.
3DHUSKER
Crosbyman that looks great. I had it running in a barrel on my back patio. It was 37 out but I have to get it right so when the temp is good on a weekend I can get to the lake and make some hot laps. :)
