Tampa Nick
- Feb 29, 2012
- 8
1995 Johnson 112 spl
The eyelet has completely rusted away. I was able to knock the pin out. I found the part number as 390001 and I found where I can buy one.
My question is, can I just unscrew the eyelet off the rod, and screw onto the existing rod? The existing rod has no corrosion and the threads are in great shape. Or will I have to remove the entire cylinder and rebuild? If I have to remove the entire cylinder, does anyone know where I can just buy the entire cylinder with the rod and eyelet included?
Thanks
Thanks
