I have a Johnson 200 HP that I changed the seals on. The prop shift would spin freely before but after changing the seals it is hard to turn. It will turn but I have to grab it firmly. I’ve took the the reverse gear out to make sure it wasn’t getting in a bind and it still did it. Could the new seals be causing this?
