LargemouthBass21
- Sep 29, 2018
- 207
I found a free 1964 Yachtwin 3hp on the side of the road last fall. It runs but only on full throttle (no idle/midrange) and I haven't been able to work on it since fall because Michigan . I am planning on a carb rebuild among other things. I think the ignition, coils, points are ok because I am getting spark. It is not blue but it is there. I read somewhere that on these motors the color doesn't matter a whole lot. It has compression (haven't tested but can feel it when I pull it over). Anyway the fuel comes out the fuel line fine, but the threads on the connector are messed up or something where it hooks to the carb because it leaks steadily. Fortunately it doesnt leak at the fuel tank or petcock valve so I'm good there. I'm planning on Ethanol free gas only so it shouldn't matter but I'd really like to convert to a rubber fuel line. Is there a good way to do this?
The attached picture is what my connector looks like, except mine leaks a lot, has wonky threads, and the tip is bent.
Thanks everyone
Thanks everyone
