I have a 1974 johnson 135. Hopefully this can help someone else. I believe the design of the plug wire end connectors that attach to plug are a poor design. I belive it leads to failed coils due to higher resistance because of the scetchy connection of the little pin that just sticks into the plug wire. I had two new coils fail with a cracked plastic cover which is caused by excessive heat in the coil which is caused by the coil working too hard to overcome the reaistance. Ohm checked the wire and noticed the gauge went to infinity if I moved the wire at all. Ended up being the the little spring with needle connection issue. I replaced them all with crimp on automotive connectors (much more of a possitive connection) and had no more coil problems! Too me this is probably why so many people have coils failing, imo.
I was really surprised to see such a flimsy design when I removed the boot. Other than that the motor is impressive in its design, simplistic but effective, and runs great for such an antique
