bsullivan10
- Dec 31, 2018
- 1
I am working on a 1977 Johnson 25 for someone. I did carb rebuild and put a new impeller on it. It runs good and is spraying water out of the two holes on the exhaust housing but not the pee hole on the bottom of the cowling. Im not sure if it is getting adequate water and cooling properly. I took a laser thermometer and read temps while it was running. Some places got up to around 240 and I cut it off. Anyone know what temp these engines should run at and how to fix it? Thanks
