havoc_squad
- Mar 5, 2011
- 693
Does anyone make an official cap plug for the OMC wire harness plug used for VRO pump?
This is regarding VJ90TLASB 1990 Johnson 90 hp.
I've already got everything removed and ready for re-assembly on my VRO delete.
Regardless if it does exist or not, could I drill out the pre-existing wire in the male side that goes to the VRO and epoxy the holes made to make a cheap/reliable plug that won't short anything out?
I don't like leaving uncapped connections, nor cutting off proprietary fittings on the main engine harness unless no other option.
Also, is there a way to NOT destroy the OMC fuel line clips when loosening/removal? I never can figure out how to salvage them.
