Vintage Johnson JW-10
Nikkid1981
i recently recovered a Johnson 3HP -JW-10 (1952-1954) boat motor and I was wondering if anyone knew the value of this motor or if it’s even something sought after? Not sure yet if it runs, or even who I could bring it to in order to test that? Any ideas or information would be greatly appreciated.
F_R
Lots of them still out there and running well. They are not worth a bundle of money due to the abundance. But still a popular motor among the old motors collectors. Unless they have already been replaced, it needs new coils as well as the usual ignition/fuel/water pump service. Check out the Antique Outboard Motors Club www.aomci.org
Crosbyman
I have purchased them as low as $30 Some folks probably got them free !
Also seen some in the hundreds …. it all depends on condition (aka COMPRESSION and innards if stored properly or not)
the rest is usually easy to fixup … parts available (clean up the carb and redo electricals, impeller seals tec…)
http://www.outboard-boat-motor-repai...%20Tune-up.htm
http://www.outboard-boat-motor-repai...%20Tune-UP.htm
Little kickers are great for trolling in the back woods and beats a pair of oars anytime :fish2:
why not start yourself a new hobby and refurbish it yourself …..they are easy to work on with a minimum of tools
a flywheel puller is needed but you can reuse that on your next project :peace:
2- ignition coils will need replacement .. likely all cracked (Chineese ones are down to $13 CDN on EBAY )
lots of utubes to watch and learn including ADJUSTING POINTS & TIMING which may seem complex at the beginning but easy as pie
http://www.youtube.com/watch?v=ga1Cj...ature=youtu.be
lots of folks here to help and on the AOMCI site ASK A MEMBER section under RESOURCES
time to get some grease on your fingers :hungry:
https://www.bing.com/videos/search?...C6481FD305CC48D3B4E5C6481FD305CC&&FORM=VDRVRV
Sirrobin53
Mine is still running.
