J225PXEEC. I purchased the boat to duck hunt with and I find myself in shallow water every day out with it. When I trim the motor up it causes the motor to start sneezing a little and then it gets to a point where it will cut off. If I drop the motor to take off it will bog a little and then its like it gets that normal fuel and will take right off. It has good compression, rebuilt carbs and the VRO was deleted, taken off, and replaced with a conventional pump of adequate size. If its trimmed up and i try to restart it, it fires right up. I put it in gear and it will run as long as I give it a little more throttle than what I would like to be using while picking up birds, decoys etc. Any help would be appreciated
