Compression 90 9.9 Johnson
Bob dobolina
Recently purchased ‘90 Johnson 9.9. Compression reads 80 psi in both cylinders. My cousin Freddy says I need at least 95 psi. Can anyone help?
Fire the cousin.-----Does the motor run properly ??-----Is your gauge accurate ?-----Did you try pulling it over a little faster ?
Crosbyman
did you cousin Freddy :target: make you an offer to get off your hands ?? :nod:
Bob dobolina
Thanks. I will try pulling faster. It seems to run fine. The gauge is brand new first time I’ve used it
oldboat1
Test with the second plug removed (both plugs out for spark testing). Crank until reading stops increasing.
wannabewelder
Did you do a wet test with oil? Shoot some WD in the hole, turn over to lube and retry.
I have 3 compression gauges with 3 different readings. 1 is old and 20lbs low. I use it for dead heading gaskets and cracks.
