DWM76
- Sep 4, 2018
- 47
Background: Motor came with boat and trailer I bought to get me and the boy out fishing. It was a bonus add on to the sale so I decided to try and rebuild it as a learning opportunity. (no outboard or mechanical experience)
There are other threads with the work I did to date from the lower unit and up. At this point I am trying to get the old girl to start.
Compression 90-92psi on all 3, good spark on all 3 (using inline tester), carbs removed and serviced, reeds look immaculate.
Might be doing something wrong but here is how I am trying to start it:
6 gauge positive (from starter solenoid) and negative wire (from ground) to marine deep cycle (750), load tested and on a tender.
Ignition lead to starter (red / 20A fused) and amplifier (purple) connected to positive battery post. I touch the ignition lead (white) to starter solenoid and starter motor cranks great but engine won't fire. I get some barks and coughs and some puffs of exhaust from the prop, 1 loud backfire, but no go. (new clean premium fuel 50:1 w/ 2stroke oil)
Ended up with oil/fuel (dark) in trash barrel water and fuel (clear) out the front of the carbs at the intake manifold.
I cleaned out the carbs and used kits to replace gaskets etc. Needle valves looked great, lightly seated then opened 1 turn.
Any tips on what I should look at? Should I go back to the ignition and check amplifier output to coil, coil output to HT lead, points trigger back to Amp? Or do I have a fuel/air mix issue? Or am I just way off and making things worse?
I have tried a few places in my area looking to get a knowledgeable outboard mechanic familiar with these old outboards to look at it but they all say it's not worth it without looking at it.
Maybe I should throw in the towel?
Thanks again,
Thanks again,
