Rods are fractured when they are made.-----Caps will only fit on one rod and only one way.----match the dots and tighten rod bolts a bit.----They can / should be lined up perfectly.-----The rod in the second picture appears to be scrap to me.----Different part # on the crank is due to different / various seal arrangements on the splines for the driveshaft.-----Study those parts arrangements.
