I've started this topic to ask you guys for a help.
I have this engine for some time running fine and few days later it got broken.
Currently it wont start.
It has happened that I've let it stop on the water in gear with gas set to minimum few times. The boat was slowing down and when it almost stopped, the engine stopped (I know, not perfect :facepalm: ...damn fishing)
After the last shut off, this way I had to pull few times (even the engine was warm) and the engine exhaust banged like choked and stopped. New few attempts to start the engine I had to set the gas to 3/4 of the range without the choke, it turned few times and stopped. Now, it wont start at all.
I've checked the spark - OK
I've checked the fuel hose - OK
I've dissembled the carburettor and it looks "clean"
I've tried to inject fuel into air intake before the start without any better result.
The valve seems to have the compression as when attempting to start without the spark, there is sound of air compression.
I've looked at the coil, wondering if timing could be wrong and it seems that this model has quite fail-proof coil system. Magnet and coil is fixed.
Any idea what the "incorrect" shut off of the engine could cause?
Would you be so kind and give me some hints what and how to check to troubleshoot this engine, please?
To reach the service is quite difficult because of distance and its availability.
Thanks in advance.
Travis
