Hi guys, it's been a while since I have posted here, but here goes. Like the title says no spark. I have followed the cdi trouble shooting about 20 times and I am still confused. The engine was running fine on last use, and 2 months later no spark. My question is, how many volts ac should I have coming from under the flywheel? When I take the brown and brown and white wire off the power pack and read the voltage, I get 106 VAC, is this enough? When the wires are installed I only get something on the brown/yellow with test light, no spark. I have 5 different power packs and it is the same with all of them. Am I missing something. The engine spins plenty fast, but I took the plugs out to get it to spin faster, no change. I feel like 106 vac is not enough, but I cannot find anything to confirm this, what do you guys think? What am I missing. Also, fyi, the timing base and stator were replaced several years ago,but that was for a no charge situation, the engine started and ran fine, thank in advance...Mark
