I recently converted a 9.9 to a 15 by changing out the carburetor, Reed valve spacers, and the tuned exhuust tube. I didn't change the exhaust housing.
Question is the new exhaust tube is about 1" shorter than the old and doesn't have the sealing surface on the gearcase side.
Now that it's all together, the exhaust seems to be escaping (bubling) out of the seam between exhaust housing and gearcase. When I place my hand behind the prop (emersed in water of course), it doesn't seem like I am getting full exhasut out of it.
Is this normal. It does appear that the exhaust housing part #is different between the 9.9&15. So to change to the tuned tube, do you need the matching housing?.
Thanks
Thanks
