I store me boat in Panama city florida in a dry storage marina.After hurricane micheal passed through and tore up the whole area I was able to go retrieve my boat.I was lucky my boat was untouched and undamaged,many others were not so fortunate.
Last time I ran the boat (2months ago) it ran perfectly. Engine started normally but had very rough idle,would not make power over 2000 RPM . I drove the boat in this condition to the boat ramp and loaded the boat using the trailer winch since it wasnt making enough power to load drive it on the trailer.
I got the boat home and I suspected water in the fuel since the marina wall had blown in and the boat was rained on by hurricane force winds. However I found no water in the fuel separator.I changed fuel filter and ran the motor but no change.
I did notice a grey goo substance coming out of the prop hub that was definitely not normal. It looks like exhaust mixed with water and unburned fuel.Im going to post a pic of it if the forum will let me.
I began thinking it might be a blown head gasket so I did a compression check.Cold engine all cylinders had 90 psi+/- 2 psi.
Anybody seen anything like this grey gooey exhaust? Any help or suggestions will be appreciated.
