I have a problem with a frayed wire that was causing the shift to not work correctly. The green wire had broken completely near the boot of the shift solenoid cover. So I removed the shift solenoids cover and it seems like it's going to be hard to run a wire through that cover while keeping it watertight. Anyone with suggestion? Maybe I'm overthinking it, but I'm thinking drilling through the rubber boot and running a wires through with silicon, and then adding more silicone?
the other problem I have is reinstalling the solenoids into the housing. There is a ball and socket joint that keep slipping off when I push down on the rod, probably because it's not going into the hole below. Is there a trick to it?
