I have a 1980’s Johnson 110 vro that has been acting up! Will start up fine but when you put in gear it sometimes cuts out and when you give it throttle when it is in gear is just bogs down and runs like crap! and sometimes will pick all of a sudden and run fine! I have replaced fuel pump new plugs new wires new starter new fuel line new fuel water separator! Anyone have any advice compression is good on all cylinders also!
