Joe Reeves
- Feb 24, 2002
- 13,262
I put voltage to the purple wire and no heat, but saw the brief spark at connection. The green wire wants to weld if I touch voltage to it. I must have missed something. A solenoid would be the easy fix, but is there a way to tell if it's not the leg of the oil pump?
There is no purple wire unless someone rewired the unit... it would always be "Blue" & "Green". The problem is simple... either that green wire is shorted to ground somewhere or the solenoid is shorted internally. The lower unit needs to be dropped in order to find out which is the case.
