I replaced the thermostats and bypass valves the end of the 2017 season because the #1 and #3 cylinders were not getting up to proper temp, but the #2 and #4 were getting to proper temp. The power head is off the engine and in my workshop. It's still winter here in northern Vermont, so it will be a little while before I can retest the temperature of the cylinders.
I do have a spark plug gap tester and have confirmed all 4 cylinders have spark, I think the gap was set to 5/16"when I tested. I could hear a snap, I'm just wondering if it was a loud snap. I ordered a flywheel puller so that I can do a visual inspection of the stator and so I can consider taking apart the crank case to look at the pistons/rings. The #4 cylinder compression has me thinking that since I have it apart this far, maybe I will continue going all the way to replacing the rings or having the cylinder bored out and getting an oversized piston.
