Hello All! Long time site stalker, first time poster.
I recently purchased a 1990 Nitro Tracker with a Johnson 90hp (TJ90TLESB). The boat had been sitting a while so I rebuilt the carbs which made a world of difference. I checked the timing with the Joe Reeves method and it was quite far off. The manual calls for 28° @ WOT. With the JR Method, I was seeing about 15° BTDC. I moved the spark advance to achieve 24° BTDC, performed a link and sync, started her up, and idle sounded great at around 700rpm with muffs. Everything seemed to go as planned but as I went to hook back up the throttle linkage, I found it to be in a nasty bind at the idle position. I realize this is due to the fact that the linkage arm is now in a more counter-clockwise position per the new timing setting and the throttle cable connection is closer to the anchor postion at the air silencer base plate. Part of the problem is that the cam roller that connects the primary linkage to the spark advance lever is quite worn which means that the first linkage arm has to come back farther for the spark advance arm to reach idle position. I've ordered a new part, but the slop is a only few 16ths, and shouldn't account for the amount of binding I'm seeing. The binding is significant to the point that I can't pull the control lever back to the idle position for fear of breaking something with the force required. Has anyone run into this before? Any ideas on how to fix? The control lever is integrated into the boat and it appears that they control assembly and cables came with the boat. I thought at first I may have placed the cables backwards (I had it with the throttle on bottom and shift on top), but when I tried to switch them the shift cable was no where near close.
Thanks in advance for the insight and help!
