I have a 2000 Johnson 115 (J115VLSSS) V4 with loop charged. Rebuilt the carbs recently. Adjustments to timing, link & synced. Numerous sea trial went smooth. I took the boat finally this past Saturday for some fishing, the boat worked like a charm for the first 2.5 hrs. Then I cut off the motor again to drift and when I went to start the motor, it would not start for the life of me(same problem as to why I decided to rebuild carbs). The problem is, every time it wont start I notice there is fuel coming out of the carb plastic throat area on the bottom two carbs( port and Strbd).
Im positive during the carb rebuild the seat and float were done to specs of my Manual. So my question is would a VRO/fuel pump sticking or not closing due to diaphragm issues contribute to flooding, especially the bottom two? Or can I pinpoint it to carb float and seat issues? The carb butterflies are all closed etc etc with the linkage etc.
Thanks for any help!
