Bearskin9898
- Jun 19, 2018
- 59
I have a 1969 55hp evenrude. It was running fine on the hose would switch into gears just fine. I ran seafoam through the gas tank for about 10 minutes then topped the tank off. I put it in the water and think I may have choked it too much. It was hard to start at first and when going into reverse or forward it will almost instantly die. Especially if you give it gas. Could the motor just be flooded? Fouled plus?
