Hey folks,
I've got a 200 Johnson that I thought was running just fine. However, I decided to check my compression and found out that my compression was
1 - 100 psi
3 - 25 psi
5 - 105 psi
2 - 100 psi
4 - 100 psi
6 - 105 psi
I pulled my head of and looked at #3. It is black on the top and there are two significant grooves. I assume that i need to resleeve this cylinder. My question, is can I use the same piston? Just put in a new sleeve and rings? i don't see any damage to it other than the carbon built up. The head has some dings in it. I assume is from the ring that let go.
How hard of a job is it to resleeve?
1 - 100 psi
3 - 25 psi
5 - 105 psi
2 - 100 psi
4 - 100 psi
6 - 105 psi
