MTboatguy
- Jul 8, 2010
- 8,988
Well have my new to me boat re-rigged and was going to test the engine in the barrel, install battery turn key over........nothing pure quiet, I know the engine has power cause I can activate the choke from the remote control and I can jump the starter with cables and it will spin, but it won't engage the fly wheel to turn the engine over.. I am thinking I either have a bad solenoid or a bad neutral switch in the control unit. Is there a way to bypass the neutral switch just to check if it is the bad part? I know these solenoids look like an old Ford one, but are built differently for use with a boat engine. Also, I looked by I don't see a fuse in the hot line, is there one somewhere that I am not seeing that can prevent the starter from engaging?
Thanks for any help you can offer.
