bigdhill96
- Apr 27, 2015
- 20
I just recently bought a 1995 johnson 130hp v4 , took it out to the lake yesterday and had to prime the fuel bulb to start, got it started up and ran fine, but when I idle or trolling around slow the alarm starts to beep about every second or so...I can rev it up and the alarm stops. The alarm doesn't come on if I am going fast across the water, it only comes on whenever I am idling or going slow. After shutting the engine off a few times every so often I have to pump the primer bulb back up to start it up cause the bulb gets soft. It will then run fine, but whenever I idle the alarm starts to go off again . Does anyone know what the problem could be or where to start ?
