70hp Evinrude 70673D...120 on all 3 cylinders (before warm up)
I have new pistons, rings, rectifier, coils, fuel lines and tank, spark plugs, fuel pump, rebuilt and cleaned carbs many times, rejetted per Boyesen reeds recommendations , no water leaks, do not see any fuel leaks.
rebuilt it...started it up...the manual says to set the carbs closed..did it...set cam on mark...did it...and while in the tank and in forward gear set the pick up timing to 3*-5* ATDC. There are no marks on flywheel for ATDC so I measured the timing marks BTDC and measured over the same distance on the ATDC side and scribed a mark and set it there. idles fine.
When I try to give it the slightest bit of throttle, it immediately bogs down and dies. I've pumped the primer, tried going really slow, ...I don't want to ruin the motor.
What am I doing wrong here? Could a powerpack do this?
Any help is appreciated, Thx
