Any ideas as to a good starting point for mixture screw? These are the 5 point torx and the old setting was 8 turns out. It did't idle well before carb cleaning.
6 turns is a good start point. You cannot adjust these out of water on a hose.. Boat has to be in water,in gear, untethered and engine level to adjust.
