Removing 115 lower by myself today. Any suggestions how/where to safely store while off? Thanks
S scooot Recruit Joined Jun 1, 2018 Messages 3 Jun 1, 2018 #1 Removing 115 lower by myself today. Any suggestions how/where to safely store while off? Thanks
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,195 Jun 1, 2018 #2 Anywhere you want. It isn't going to blow up or anything.
S scooot Recruit Joined Jun 1, 2018 Messages 3 Jun 1, 2018 #3 Meant safely as in not getting damaged work area is concrete.
DRCrowe Petty Officer 3rd Class Joined May 22, 2018 Messages 84 Jun 2, 2018 #4 Put a piece of cardboard down. Be patient with the shift linkage, that is the trickiest part when I've pulled/replaced mine.
S scooot Recruit Joined Jun 1, 2018 Messages 3 Jun 3, 2018 #5 Thanks. Should it be in neutral or does it matter. Btw, I'm replacing impeller.
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 36,274 Jun 3, 2018 #6 There are different ways to disconnect shift rod.-----Your model # is ?
