Kingfisher1970
- May 31, 2018
- 3
see attached picture
What is this wire?
What is the rubber tube it goes through?
Where is it going in the motor?
Is it possible to remove from the motor so I can replace my entire wiring harness?
This wire comes out of the wiring harness, goes into a rubber tube that is not heat-shrink and is bonded to the wire as far as i can tell. its a little lumpy inside, as if there is some kind of connector or something in there. there is a tab at each end, almost like little handles.
from there, it goes through a clip, then dives into the motor via a sealed orifice that seems to have a rubber plug that is also molded to the wire.
my wiring harness is completely toasted. i need to replace it ($160...) and this wire is part of it, but i cannot see how to ghet it out without cutting it or opening up my motor, which i do not want to do. Is that just a fusible link? I have looked at several wiring diagrams and parts diagrams and i cannot determine what that is.
the wire that goes from the harness to what i think is a fusible link is maybe green. the wire is so corroded and insulator is so cracked and rotted i cant really tell.
thanks!
What is this wire?
thanks!
