I just put a new fuel pump in last year and replaced all of the hoses and I used some seafoam spray, also
That may be true, but (while I'm no pro here) RCO is right..
The primer bulb in the fuel line between the gas tank and the engine is nothing more than a manual fuel pump.
IF:
1) All the lines and connections check out and there are no leaks and no air getting in,
2) Fuel tank is vented properly
3) Any fuel filters/water separators are clear with no blockage
4) Fuel pickup screens in tank aren't blocked
etc....
If all that checks out and yet in order to keep the engine running, you have to use the primer bulb (manual fuel pump) then it's likely a bad fuel pump...
Can you disconnect the fuel hose where it goes into the carb from the pump? (Edit: Put open end in jar or suitable container to catch fuel...)
Then crank the engine.. Does fuel spit out?
Again...
NOT a pro here.. RCO and others can/will guide better.
Just adding some thoughts...
Hope it helps!
