BowPro
- Apr 25, 2012
- 73
2005 Evinrude 225 HO DI. Running down river and lost a lot of power, it slowed down immediately, and I could hear knocking. I shut it down and then tried to start it just to see what it would do. It was locked up. About 5 minutes later, after cooling down, it started up, but had the knock. I shut it off and towed it in. Pulled the plugs at home and the middle plug on the port side showed me which cylinder gave out. All other plugs were up to par, and their respective cylinder compressions were 118 to 120. The jacked up cylinder, with the metal shavings welded to the plug, was zero. Time for a new powerhead I imagine. Would a diagnostic show what caused it? I cleaned the plugs and reset the widened gaps to .028, and cleaned out the exhaust pressure nipple as well, just prior to the failure. I certainly believe that that part was concidental. I did that because it seemed to be a little sluggish on the hole shot in the days before. Any ideas on things I can look at or test, just out of the curiousity while it's here at home? I don't want the problem reoccurring after a rebuild. Pic of plug included for those that wanna make an educated guess.
