Vandkanten
- May 21, 2018
- 73
According to the service manual I should be able to measure this on the stator output:
Brown -> Brown/Yellow, 720-880 Ohm, 150-400 Vac
I measure this: 750 Ohm, and 106 Vac when I crank by hand (A hard pull)
I am able to measure max. 170Vac by cranking by machine at max RPM
Even at 170Vac, I didnt got spark. But maybe it couldnt generate enough amp.
What is your oppion, should I assume that the stator is bad and replace it?
